Home › Forum › Ask A Member › Model J Johnson
  • #3130
      My Uncle has a small Johnson that has on the flywheel
      "J XXXXXX" (J followed by the serial number)
      Would this be the J25 Johnson? I don’t see just
      a plain "J" model listed. Seems like I’ve read
      about this problem before, but am not able to
      find the answer.
      Thanks!
        Johnson made several J type models over the years so if you can find the serial number on it, you should be able to identify the year and model. It might be one of these singles:
        J-25……’25 – ’32
        J-65……’33
        J-70……’34
        J-75……’35
        J-80……’36
        #28377
          Mumbles, the serial number is on the flywheel, right after
          the letter "J", but I didn’t write it down. But now, thanks
          to you, "I get it"!, and will figure it out next visit.
          Thanks!
            #28452
              Interesting Tubs, will have to see if my Uncles was made In
              South Bend or Waukegan! Thanks!
