Home › Forum › Ask A Member › Mk 25 starter
  • #60614
    cheetahgod
      thanks. The spring is intact and I removed it carefully. H
      #60620
        I let it come out, It was filthy. Clean the spring, then install it. Watch out it will get ya! Get a book. Just like fixing a fish tape.
        #60624
          Too late now, you already have it apart. But often that old grease problem can be solved by simply dumping a bunch of mineral spirits in the housing and pull the rope a few times, then drain. The remaining mineral spirits/dissolved grease residue will provide continuing lubrication.
