Home › Forum › Ask A Member › Mike Bowles Condenser Tester Questions
  • #6196
    green-thumbs
      I would like to build the Condenser Tester from Mike Bowles instructions.
      Would someone who has made this condenser tester comment on 1) enclosure
      and 2) what did you hang the electronic components on…leaving them to flop around
      loose does not seem a good idea.
      Radio Shack is long ago history.
      I do have the listed items needed what I do not have a a grasp of how to make a safe
      and durable test device. I have condensers to test and a soldering iron.
      If the process of building the condenser tester is posted online I would appreciate
      a point in the right direction
      Thanks
      Louis
      #51813
        I don’t know which came first, the chicken or egg, but here is a commercially made chicken (or egg) that I’ve had for 50 years.
        If I were to make one today, I might use the terminal strip, or I might use a piece of perf board http://www.ebay.com/itm/GC-Electronics- … SwnHZYUdO9 [/size
        windows screen capture
        #51833
        green-thumbs
          Thank You
          Perf Board sounds like what I need
          Louis
