Home › Forum › Ask A Member › mercury timing belts 20140
  • #293292
    Michael Brown
      How can we obtain these parts. Seems to be discontinued nearly everywhere
      #293293
        folks at Johns’S old mercury maybe can help
        JohnsOldMercurySite – Index page
        #293295
          Try polybelt.com give them part ## and measurement # teeth.
          #293309
          green-thumbs
            It is unlikely that the toothed drive belt is unique to Kiekhaefer
            Mercury as they would be way more
            expensive than off the shelf item,
            Easy way to identify a belt to to
            read identification information printed on the belt. If it is worn
            off, count the teeth and measure the width and length. Compare to
            belt catalog information (hard copy or on line) See if the Mercury part # crosses with the
            belt catalog part #.
            A positive identification avoids
            purchase of a part you can not use and can not be returned,
            Louis
            #293311
            elgin2
              Try McMaster-Carr.
              #293312
              CHUCK
                Are the specifications published for Belt #20140?
                #293319
                MarkD
                  I tried McMaster-Carr and none match based on my measurements. However, Amazon has what they are calling a compatible one. Has anyone tried one of these:
                  https://www.amazon.com/DVPARTS-70-20140-Compatible-Quicksilver-Outboard/dp/B0CY2NBF8R
                  #293321
                  CHUCK
                    There is only one review on Amazon for that belt and it says NG.
                    #293337
                    Dale
                      Mark those belts are very hard to install.  It sounds like previous buyers had some size issues.  It might be worth a try, because they are hard to find.  The price isn’t to bad. Maybe Dave can jump in and tell us how to install one.  Maybe there is a way to loosen the distributor a little.   I had a bugger of a time getting mine on and it was original and it showed some wear.
                      dale
                      #293348
                        TRY        Amazon Has 13 of them
                        DVPARTS
                        Timing belt
                        20140 – 7020140- 27976501
