Home › Forum › Ask A Member › Mercury Model and Year ID
  • #2999
      I only see a serial number on this Mercury part motor.
      It’s a twin cylinder, probably about a 7.5hp. Comet is
      printed on the block. It’s serial # 5145303.
      Would like to come up with a year, model and HP.
      Help appreciated. I looked at some serial number
      data online and the closest I came up with was
      an 80hp …… NOT.
      david-bartlett
        My guess is 1978 Model 75M.
        #27231
        20mercman
          That serial number places it in the 1978 year. 7.5 hp. would have "Comet" printed on the block. Wonderful little motors!
          Steve
          #27239
            Thanks Guys! Now I can look up what’s missing
            by the loose wires….. coils I suppose!
            chinewalker
              Looks like you’re missing the power pack and coils. I have some used coils if you need some…
              #27247
                I believe I have another 7.5 Merc in the bunch, so
                I may have parts. Most of the newer Mercs in the
                bunch (1970’s-80’s) are missing the lower units /
                gear boxes. Where they prone to problems like
                the early Mercs, Mk5, 6’s, etc?
                I also have my dad’s old 1973, 7.5 Merc that’s complete
                and I need to get running some day…. too many
                projects!
                chinewalker
                  The earlier 6/7.5 and 9.8 hp twins (as many of the Mercs of that era) had issues with rusting lower unit shafts that allowed water to enter. Worst was the driveshaft, directly below the water pump as that would puddle a bit of water and then just sit. Mercury was very late to the stainless shaft game, as they made the switch in the mid 1970s.
                  #27250
                    There were a few models that had stainless in 1975 but by 1976, they ALL had stainless. And Mercury never looked back. What a difference it made in their product!
                    #27254
                      Would the newer, stainless steel shafts from a later 7.5 Merc
                      fit the older units like my dad’s 1973?
                      Thanks.
                      20mercman
                        quote Buccaneer:
                        Thanks.
                        I believe that the newer shafts would work in the older motors. I do know that in the 20hp line, from 1963-81 that the new style stainless drive shafts will work for all years. There is a slight difference in the water pump drive, so you may need to update the water pump impeller and drive key with the shaft.
                        Steve
