Home › Forum › Ask A Member › Mercury Mark25 water pump service
- This topic has 6 replies, 4 voices, and was last updated 9 years, 8 months ago by
garry-in-michigan.
March 5, 2017 at 6:23 pm #6470
As you might guess by my YouTube channel I’m more of an OMC guy, but I do have a few Mercs in my collection to work on. I’m about to do the water pump on my Mk25, and I’m just curious if there is anything special I should know before I try to drop the lower unit. Thanks in advance.
-BenOldJohnnyRude on YouTube
March 5, 2017 at 9:31 pm #53891Ben,
If you don’t have the Mercury manual I highly recommend you get one. I believe there is a copy on Garry’s Dropbox somewhere.
Also lots of good info at Johns Old Mercury site.
Carl’s folks have several special tools but a clever guy like you can make your own.
I repeat, get the Manual # C-90-25500
March 5, 2017 at 10:29 pm #53893March 6, 2017 at 12:10 am #53901Thanks David, I will get a manual. I know it’s certainly not an OMC just from what little I have messed with it so far. That’s pretty much the story with any of my Mercs. Even the ones I have worked on. They are different animals from what I’m used to. They are kind of fascinating but I usually need OMC therapy after working on one.
March 6, 2017 at 12:40 am #53905mark 25 pump is easy to do. 3 bolts drop the lower. put it in forward first. makes it easier to reinstall. the pump cover is right hand threads make a tool to remove. if you have a problem call me 1 914 three one zero 7086 Dave . or email me daveb409@hotmail.com.
March 6, 2017 at 2:10 am #53916Thanks Dave! That’s what I was hoping for. I figured I’d need to make a tool to remove the cover. Right hand threads and pUT it in forward before dropping the LU. Excellent! Thank you again. I’ll call you if I have any trouble when I get to it. It may be next weekend. I’m working on the water pump on my 1978 Merc 4hp now. New impeller a year ago and it stopped pumping. Impeller already had so much set it wouldn’t contact the sides of the pump housing. 😯
March 6, 2017 at 5:57 pm #53945 -
