Home › Forum › Ask A Member › Mercury mark upper and lower seals
  • #264987
    David Miller
      Hi,
      Starting to restore a Mark58A. Which has 130psi in all four cylinders. The wire with the lead biscuit is still intact near the fuel pump.  I am reluctant to pull it all apart per the service manual to change the upper and lower seals. Is there an easier way to change them? The manual indicates, to me at least, the need to separate (tear down) the cylinder head? Including checking the internals then re-constructing the motor, going so far as checking crank end play etc.  Am I wrong in thinking that the caps can be removed one at a time then serviced or replaced, then installed one at a time?  Thanks for all answers Dave
      DAM
      #264989
        Call me 1 914 310 7086
        #265010
          You absolutely can pull the end caps out to change the seals. There are threaded holes in each cap, into which you screw screws from a plate puller of your choice. Enjoy; as this is one of a handful of ways that Mercurys are actually EASIER than OMC!
          #265277
          David Miller
            Thanks for the help.
            DAM
            #265278
            David Miller
              Thank you Dave for the information and conversation.
              Dave M
              DAM
              #265280
                Anytime.
