Home › Forum › Ask A Member › Mercury Mark 6
  • #4150
    sbrown21
      I just bought 2 mark 6 Mercury’s that were locked up for 45.00 $ brought them home and freed the cyl’s. but noticed one was welded behind the prop. I than looked at the other one and it was cracked in the same place on the lower housing behind the prop. Is this a common problem ? Will I be able to get into the gear housing on the lower unit that has the cap welded ? The one motor is nice all the parts except for the weld. I think it will run after I check coils , the other is all there except the crack around the lower assy. broken starter spring and broken starter cable. Can these be fixed and are they worth fixing ?
      #35614
        yes that is a problem. not a big deal call me 1 914 310 7086.
        good motors but hard to do a fuel pump.
        #35619
          Boy, if cracked Mark 6 gear cases are not a big deal, I sure would like to know your secret…..
          #35622
          20mercman
            I would love to have a die to cut the threads into the housing after welding. Then it really would be "no big deal", as I could weld them with full penetration without worry. Hard to weld it that does not distort the threads, and then it is not getting the penetration you want for maximum strength.
            Steve
            #35630
            RICHARD A. WHITE
              Do you know the diameter and thread pitch? You can get that info from the water pump cover….
              classicomctools@gmail.com
              #35634
              green-thumbs
                A GOOD machinist could carefully indicate case so as to recut thread…very close work to
                get everything aligned within original specs. It can be done but given the number of Mark 6
                made probably far less expensive to find a good used replacement even though such damage
                may be a weal point of the design. If you are the machinist probably just an interesting
                job on lathe or mill. BYB thread cutting both internal and external is usually done with a
                60 degree single point tool. Tap and dies in larger sizes tend to be cost prohibitive
                if infrequently used. Given the irregular shape of gear cases the first step to getting the
                alignment right might be building a holding device.
                Opinion not Fact
                Louis
                I dabble in machining. I know a great welder and a great machinist but given the time
                and cost involved a good used replacement would make more sense. There several
                ways to determine the thread diameter and pitch…helps to have a basic understand thread
                standards, cutting threads requires paying close attention to what you are doing…THE
                problem is obtaining an accurate set up so threading aligns with case and the existing
                thread in case. It can be done and there are more than a few in hobby that can do that
                level of work.
                #35636
                dockbuster1
                  Tipically the housing cracks just behind the cover if you shorten the seal carrier the cover will catch the remaining threads works fine except you have a bit more space behind the prop ,assuming the bearings haven’t been ruined by the water in the gearcase
                  #35641
                  sbrown21
                    Thanks I think I will try to shorten the seal carrier since there are some good threads left on the housing.
