Home › Forum › Ask A Member › Mercury Mark 5, first run, first problem
  • #35273
      Steve, I too am learning that these Mercs can be frustrating!
      Could you have shortened the tang on the neutral spring
      to make it work instead of reusing the deformed one?
      I messed around with mine half the day. The determination was
      that the prop "was" slipping, and that the neutral spring "was not"
      releasing! I took the gear case off (but was able to leave the "shoe piece"
      and water pump in place!) and put the stub drive shaft in the vice
      and was able to slip the prop fairly easy. Ended up making a shim
      out of aluminum flashing and put it under the prop nut cone spring.
      It would still slip, but with much more effort. While the gear case was
      off I played with the shift cable while watching the neutral spring
      and the finger that’s suppose to catch said spring…. it was not engaging.
      The only way I could get it to do so was remove the plug from the shoe
      and push the cable (and catch finger) up further and tighten the cable
      up on the top side.
      I can now run wide open with no prop slippage and I have neutral (just barely),
      but can’t seem to get the shift handle adjusted within the service bulletin
      specs.
      Perhaps I need a new spring with a longer tang!!! ๐Ÿ™
      It idles beautifully and most times sounds good wide open, but it did load
      up a couple of times.
      Murphy’s law says all the exhaust must blow the wrong direction, so
      perhaps it was lacking proper oxygen to run correctly at times.
      I’m thinking my 16:1 fuel mixture might have been a little rich as well.
      Oh well, there’s hope for it!
      dockbuster1
        Two thoughts if the cable is too taught it will jump in and out of gear tipically when the prop is slipping it is far smoother . Todays lower unit lubricants are far more slippery and could cause a lack of grab of the spring on the drum there is still 90 wt. non synthetic lower unit lube available which has less lubricity
        #35279
          they DON’T use oil they use GREASE.
          #35281
          20mercman
            quote Buccaneer:
            that the prop “was” slipping, and that the neutral spring “was not”
            releasing! I took the gear case off (but was able to leave the “shoe piece”
            up on the top side.
            specs.
            I was very seriously considering filing down the tang on the new spring, but after I was able to restore to original one, (it really came back to original looking condition,) I figured I would give it a try. It worked, so I didn’t need the other one. I had a call from Marineengine.com about another part, and I mentioned the spring. They offered to take it back, so I sent it back to them.
            As for 16:1, yes, that is really way too much oil for these. I have found that anything richer than 24:1 is way too much. These don’t need all that oil, and I have found they don’t like it. I run all my regular service Mercs, (not during break-in) at 48:1 unless I have some richer gas mix to use up.
            Steve
            #35291
              I’m not saying this should be law but I always have run my Mark 5s and 6s on 24:1 and have never had a problem. I also use 90 weight gear oil with no shift problems….but in my case that’s okay because I have nice, tight, resealed cases. As for loading up, make sure there is gas/oil spewing defiantly into the lake, from that little copper tube sticking out rearward, below the power head. Some people assume it will be water discharge but it’s a crank case drain. God Bless 1950s America….but don’t let the clam cops see it.
              #35300
                Bill, My copper tube is spewing oil and somewhat disgusting me… and it’s
                only dripping in my test barrel so far. Perhaps it needs a diaper retrofit!
                  No, that’s perfect! That’s what it is supposed to do! Be disgusting! That’s how you know it works! ๐Ÿ˜€
                  #35319
                    I realized the disgusting crankcase drain tube was oriented the wrong
                    way, so it dripped on the transom mount. Turned it around so it
                    will drip directly in the Land of Sky Blue Water.
                    Made a new gas line as well today. Old ferrule would not seal.
                    No sense spewing gas as well!
                    I too "tried" marine gear oil in my Mark 5, but wasn’t so lucky.
                    Drip, drip, drip.
                    Put some old Texaco outboard grease in it today. It was all I could
                    do to squeeze the tube "hard and long enough" to get it to come
                    out that tiny vent hole ๐Ÿ™
                      Mark 6s are tough engines to work on, for their size. They usually end up needing a LOT of work, too. They are very needy, because In the span of their lives, they are not likely to run into an owner or mechanic who has the time and patience to really make them right. So congratulations. You just graduated from an advanced course in mechanical patience and should be proud of yourself. They really ARE nice running engines, once you’ve flogged them for enough time.
                      #35408
                      green-thumbs
                        Very few outboards from any era received routine preventative care let alone expensive repairs. The relatively low value of an "old boat motor" very often reflects the fact that it
                        did not run the last time it was used. In addition to pre existing conditions many old outboards suffer from…fuel left in tank, water in gear case leading to rust or freeze damage, left
                        out in weather storage and becoming a home for rodents or wasps. Many old outboard also show
                        signs of unskilled mechanics (not aomci member I am sure.) If it was bought when HST was
                        playing the White House piano and put in permanent storage when Ike was playing over par
                        golf expect it to need more than fresh fuel and a pull on starter cord. Refreshing and few are
                        the exceptions. We who like mechanical challenges love old outboards…even if they do cause us to expand our vocabulary in frustration.
                        Louis
                        3/8 pint of Kiekhaefer Quicksilver 2 cycle engine oil per gallon of gasoline
                        All models use Kiekhaefer Quicksilver Gear Lubricant in lower unit.
