Home › Forum › Ask A Member › Mercury Mark 40H JB Weld Fix For Cowling?
  • #6216
    muskokaseaflea
      Hi all,
      I am in the middle of restoring a Mark 40H that I found in a shed behind a cottage I just recently bought. (Whoo Hoo!) Anyway….I need some advice….before I begin to repaint the cowling, I needed to "repair" some of the areas where the bolts fasten the front cowling to the power head. The original bolt holes had been chewed up to the point that the bolts would not hold the cowling tight and slip right through without using really oversized washers. I have made an attempt to "fix" the problem using "JB Weld." Now I am second guessing my repair job thinking that maybe the JB Weld will snap away when I tighten up the bolts. I realize that the proper repair would be to take the cowling to an aluminium welding shop and have the fastening areas built back up again, but I am trying to avoid any real big expense. What do you guys think? All suggestions and comments would be appreciated.
      Chris Taylor
      Muskoka Seaflea
      Ron Devries
        I imagine it would last for a bit, how much do you plan to use it? Of course welding it up would be more permanent. Not sure that would be stupid expensive to weld up. I hind sight, it would have been cheaper before the JB application……
        #52019
        muskokaseaflea
          Thanks! I can easily remove the JB Weld…..maybe I’ll get a few quotes…..I just want to make sure that who ever I get to weld it back up won’t make it worse…..
          #52026
            I agree with Ron above. I don’t think you are talking big money here welding it correctly.
            Also, that is a pretty sought after motor. It would be worth it to put a little money in it to do it right. We are not talking about a 50 dollar motor here right.
            Are you up around Gravenhurst area then? Myself and Ron are both in your general area of Ontario.
            #52028
              weren’t they a slot and not a hole? been a while since I saw them? just asking.
              #52031
              muskokaseaflea
                Hi Dave,
                Not too sure….the material around all four bolt areas were so chewed up..I just assumed they were a hole when I tried to rebuilt it…….
                Chris
                #52033
                muskokaseaflea
                  Yes….I cottage on Kahshe Lake near Gravenhurst, but my home is close to Barrie. Any suggestions on who I could get to do the welding repair?
                  Chris
                  quote Chris_P:
                  #52035
                    CHECK BODY SHOP FOR LEADS
                    #52037
                      Chris,
                      We have some talented guys in our Chapter. Im sure one of them could help. We actually just had a meet yesterday would have been a good spot to bring the cowl! Im not a talented welder, but I know a couple. Let me ask around for you.
                      Here is our chapter website
                      http://uppercanadachapteroftheaomci.yolasite.com/
                      #52040
                      muskokaseaflea
                        Thanks. I was at the Toronto Boat Show yesterday helping out at the ACBS display. If you can find someone for me I would really appreciate it! Can you email me directly if you have any luck? chris@muskokaseaflea.ca That’s two motor meets I have missed in the past two weeks……I missed the Maple Leaf meet in Ajax as well….timing is everything 🙂
