Home › Forum › Ask A Member › Mercury KG7 parts
- This topic has 18 replies, 12 voices, and was last updated 5 years, 6 months ago by
slot gacor.
October 2, 2018 at 3:32 pm #83875
This reply was modified 8 years ago by
Tubs.
Tubs.
October 2, 2018 at 3:42 pm #83877October 2, 2018 at 7:04 pm #83886Not nearly as hard as a KF5, bottom seal aim the seal lips DOWN & replace the top too. Ground one of the hi volt lugs for super fire,
October 11, 2018 at 12:09 am #84275quote Chinewalker:Do these help? I cut the insulation back a ways to allow the wire to slip under the coil without hitting the stator plate. I then slid the entire coil inside a stub of bicycle inner tube material to insulate it. Coil throws a good spark!I’m surprised that the inner-tube rubber is adequate to prevent arcing to the mag-plate. Interesting job.
February 16, 2021 at 8:51 am #230960So I’m curious. The thread seemed to end. Did the MFR-61689 coils actually work after the motor was reassembled?
February 16, 2021 at 8:56 am #230961-
RICHARD A. WHITE.
Tubs.
I believe they are just $25 for the single output.
Here is the Ebay link
classicomctools@gmail.comFebruary 25, 2021 at 6:37 am #232158Hi Destroyer of ur GOLF… I agree with Chinewalker using a Bike INNER-tube ((* low dielectric ))… If total frustration overwhelms , or as an option. Convert the SKINTILLA to Phelon. Look for parts on E-PREY , post wanted ad’s Here, ___ start now, repeat ___ until the suggested option parts are acquired !! sign me ‘Been There’.
March 5, 2021 at 7:13 pm #233055April 28, 2021 at 2:54 am #237282So, there are two yellows. What do I do with them?
Prediski Togel OnlinePrediski Togel Online Prediski Togel Online
