Home › Forum › Ask A Member › Mercury kg7 fuel line
  • #44701
    bsplit
      Thanks all for the help.
      Jim
      #44702
      outboard315
        quote mercuryman:
        My KG7 & KH7 use 5/16 copper hard to fine .
        In the smaller tubing you can get it measured I.d. or o.d. for example 1/4 o.d. tubing is like 3/16 I.d. my numbers may not be exact.
        #44740
        58woody
          I have manufactured 1/4" & 5/16" straight tube compression fittings and all NPT / Barbs as well. All fittings are brass and excellent quality.
          #44827
            Jim,
            The Firestone 10 is doing well. I have been so busy with family no time for the Firestone yet.
            Thank you very much. Never worked with a driveshaft like that.
            Jeff
            #44828
              Yes Please check with Woodie. I am working with him now on my Mark 50.
              #44909
              outboard315
                I just confirmed my KE7 carb has 1/4" o.d. tube and the KG7 carb has a 5/16" o.d. I made the line on the KE7.
