Home › Forum › Ask A Member › Mercury Kg-7 Fuel Line
  • #1407
    jimsoldhydroshop
      Hi, Does anyone make the correct Fuel Hose Line for the Mercury KG7? Thanks, Jim jehawver@gmail.com ❓
      #15339
      outboard315
        The copper line, I bought some at Lowe’s.
        #15341
          oldmercs.com has the flex one $30.00
          #15342
          jasonh
            Early KG7 had copper tubing and later had rubber. As someone already mentioned match up copper line at hardware store. You can get the rubber hose with pressure fitting and threaded end from either oldmercs,com or vintageoutboards.com
            http://www.vintageoutboard.com/collections/mercury-fuel-systems-1/products/32-23439a1-fuel-line-rubber-hose-with-brass-fittings-for-kg4-kg7-kf7-kh7-models-nla
            #15343
            RICHARD A. WHITE
              I like the copper tubing….personally…
              classicomctools@gmail.com
              #15345
                was changed with the KG7H with all the vibration they cracked with copper. just a note.
                #15346
                ddoyle
                  Nothing a yearly annealing couldn’t fix 😆
                  #15349
                    Or replacing.
                    #15350
                    jimsoldhydroshop
                      My KG7H had the Flex Rubber Hose. That’s what I want for my restoration of both my Kg7 & Kg7H Motors. Got them on order, Thanks, Jim
                      #15358
                      jw-in-dixie
                        The KG7 I bought in about 1950 was almost new and had copper. It broke on the end attached to the filter. 🙁
                        I replaced with rubber. Now I use plastic.
                        JW in Dixie
