Home › Forum › Ask A Member › Mercury KF7 Remote Steering
  • #304493
    Aidan Smith
      Currently setting up a KF7 for a “daily driver” motor for my 1953 Blue Streak Runabout.
      B-Stock class, designed for a normal leg KF/KG or Quickie lower.
      I have a Quicksilver KG7, but would like to keep the wear as minimal as I can on that motor until I can afford to repair the L/U if needed, as I am newly in college.
      Currently, I am building up a nice KF7, but I have found the KG7 steering bar does not look right on the KF7.
      The KF has a front mounted bar while the KG has a rear mount. Is there a way to use the KG bar on the KF?
      Or should I be looking for a different style steering bar.
      Any help would be great, thanks!
      IMG_3425
      It is mounted right behind the tiller mount, and on the KG it is mounted behind the water jacket and cylinder head.
      IMG_3427
      Lower cowl still fits.
      IMG_3428
      1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
      1955 Feather Craft Vagabond - 1956 Mercury Mark 55E
      #304521
      CHUCK WEBSTER
        The front mounted steering bar should be reversed.
        #304918
        COOPER JESS
          The front mount bar is smaller in that it only has a slight bend. The holes to attach the steering cable have to be inline with the swivel pin to wok properly.
          #304919
          Aidan Smith
            Cooper,
            Yes, I have been informed of that. I am looking for one now. If I cannot find one, I am going to make one most likely.
            #304985
            Douglas Follett
              Aidan,
              I have this if you are interested.
              Sincerely,
              Doug
              #304986
              Douglas Follett
                Aidan,
                I tried sending you a pm,  no luck.  Tried posting a picture on this thread, still no luck.
                I can text you a picture or you can try to pm me.
                Doug
                #304989
                Aidan Smith
                  Doug,
                  Thats awesome, thank you!
                  The website is “under construction” right now I believe, so the best place to reach me is email.
                  smithantiqueoutboards@gmail.com
                  Thanks!
