Home › Forum › Ask A Member › Mercury kf7
  • #277282
    Jason Chisholm
      Is this factory or did someone just drill it for a shear pin?
      Jason chisholm
      #277284
      CHUCK WEBSTER
        I think it has been drilled.
        #277286
          I have a couple and they don’t have that hole in them.
          #277292
          Jason Chisholm
            Does anyone think I could run a shear pin prop with this or just the standard clutch pack propeller.
            Jason chisholm
            #277309
              I think a brass shear pin would be fine and I suspect
              you won’t be the first one to do so.
              #277316
              Dale
                Jason I am surprised our Mercury guy has not popped in on your problem.    Mercury make a sieve that goes over those splines.   You have to use a different propeller and a shear pin.   Sometimes a propeller shaft like your gets real rusty.  Mercury did not always use stainless steal on there drive components.   Be patient Jim will be around soon.
                dale
