Home › Forum › Ask A Member › Mercury KF-7 water circulating question.
  • #246161
      the early one’s had the cooling water cool the bearing and exit the swivel pin the was changed and exit the exhaust.
      #246227
      mercuryman
        Here is what the hole should look like about 1/8 ” I have had a lot of 10 hp Mercuries Power Heads off never saw a hole that big. Was going to send photo but its too big.
        #246228
        mercuryman
          Here is photo
          #246290
            Mine looks to be 1/2″ all the way through.
            I’ve been looking at some you tube videos that
            show the exhaust housing when they are running
            and the ones I have found don’t put out the water
            through the holes that my mark 7 does. I checked
            the cylinder temperature when it was running and
            it was in the mid to high 90’s and the water temp.
            in my tank was 85. I remember checking the
            exhaust housing too and it was way higher but
            I don’t recall what it was. I had another lighting
            6 years ago. Replaced the coils, condensers, all
            the seals, and it needed a prop. I ran the motor a
            lot the next summer and then passed it on. I cant
            remember how much water came out of the holes
            on that one. The coils and condensers in this one
            look resent. They have been replaced anyway.
            Although the holes were open there was a
            considerable amount of carbon build up in the
            exhaust housing. Maybe all that carbon was
            keeping the water from exiting the holes. If this
            motor has ever been apart its been a long time
            ago. I need to get gaskets and replace all the
            seals. I think I’ll set it aside and save it for
            something to keep me busy this winter. Thank
            you to all that responded. Its very much
            appreciated.
            https://youtu.be/rXy43dZuPNg
            #246299
            LLOYD LAUTNER
              Looks and sounds great! Congratulations.
              #246321
                That Merc sounds like it means business in the barrel, and it proved to be true on the boat!
                Nice motor!
                  Here is the story on the Mark-7. A museum
                  had it stored in an unheated storage building.
                  It was just laying on the floor under a plastic
                  tarp. The magneto lever was frozen solid.
                  I gave them the $50.00 they were asking.
                  The motor had a 1959 Ohio registration tag.
                  Its a 1953 and I suspect it last ran in 59.
                  The plugs were J-7-J’s and they had never
                  been fired. Its been a long time since you
                  could buy any of them. Most spark plug
                  charts don’t list them anymore. Gas tank
                  and carb were clean. No water in the gear
                  case. Impeller had taken a set but it was
                  still tight in the cartridge. So I put some
                  OMC style coils in it, along with some
                  fresh105, washed off the silver painted parts,
                  and waxed the green parts. Stuck it in my
                  trash can, put in some gas, and it started
                  right up.
                  I did put the red paint in the mag lever but
                  the rest of it (I believe) is original. There
                  are some scratches in the tank paint though.
                  I wouldn’t be surprised if that happened at
                  the museum. I ran it a couple times a day,
                  most every day, for about a month two
                  summers ago. It will do 20 mph on a 12′
                  Sears and sounds like it’s doing 100. I got
                  some ear plugs on about the 3’rd day. Showing
                  my age I guess. Great motor. Its a surprise the
                  first time you slide the mag lever over to fast.
                  #246334
                    Tubs – nice find at a great price! Good looking motor.
                    1982 Evinrude 25hp
                    #246344
                      They do have a ferocious, take-no-prisoners growl, when they run. Nothing wrong with them…..it’s just the way they are. It’s like Carl himself is under the hood, with a big cigar.
                      Hey, is that an app for your cell phone or an actual, hand held GPS? I haven’t been able to use my phone in that way yet, not that I have tried very hard….
                      • This reply was modified 5 years, 2 months ago by billw.
                      #246360
                        I would describe it as more of scream than a growl.
                        I like all the Technology in a cell phone
                        except the phone part so I don’t have one.
                        I use one of these. It takes OK pictures
                        inside and great pictures outside. No
                        special battery. Just 2 AAA’s. Smaller
                        than a pack of cigarettes. Its an early
                        Garmin nuvi 205 GPS. About the same
                        size as the camera.
                        • This reply was modified 5 years, 2 months ago by Tubs.
