Home › Forum › Ask A Member › Mercury KE4 Water Tube
  • #22217
      I think that gasket is for a ke4.
      #22221
      richardg
        The gasket goes above the power head gasket. The flat sits up against the lower jug.
        Note that on the early finned style exhaust manifold there was a metal strip that sat under the lower cylinder.
        #22222
        brian-grigsby
          quote green thumbs:
          If anyone is interested I can send a photo of the device to guide bend of replacement
          water tube. Simple to make and very helpful.
          Louis
          I’d love to see a pic Louis. Brian.
          #22230
          green-thumbs
            Small gasket goes on top next to powerhead centered on water tube flare. The extra
            thickness "should" be enough to seal around tube. I use Permatex gasket sealer.
            Mercury Illustrated Parts Manual for KE4/Mark 7 is on Western New York chapter site.
            The design of Mercury K Models is well thought out and logical but they are different .
            Louis
            #22234
            green-thumbs
              Small gasket goes above large gasket against powerhead centered on flared water tube.
              Apparently an "O" ring can be substituted.
              Louis
              #22302
              jpatti75
                So, would putting an o-ring under the flare AND the small gasket above the powerhead gasket be overkill or too thick seal properly?
                #22339
                green-thumbs
                  All that is required is a water tight junction between exhaust/driveshaft housing unit and water jacket so that water flow is from water tube into water jacket. I suspect the "O" Ring is located concentric to water tube not under flare as is often mentioned. I use the small gasket A bit of leakage past the flare into the lower on twin will do not harm and may do a little good
                  on a single as far as cooling the exhaust gas.
                  The large gasket seems to have evolved from a combination of gasket and metal with
                  the metal cover over exhaust hole to a plain gasket only. I wonder if the KD and early KE
                  twins require the metal or if a plain gasket is sufficient. I guess a new question.
                  Louis
                  #22381
                  jpatti75
                    Thanks for all of your inputs, Louis (and others) …very helpful!
                    JP
