Home › Forum › Ask A Member › Mercury KE4 impeller help needed
Viewing 10 posts - 31 through 40 (of 49 total)
  • #200340
    ROBERT LAFAYETTE
      I saw this great article by Gary Orloff in Jan 2008 AO
      Maybe check the pump housing to determine if
      installed incorrect I.e. 180 degrees out?
      KG7
      #200343
      richardg
        More obvious is the little metal key in place on the prop shaft that actually is what engages the water pump impeller so the impeller spins with the prop shaft
        #200345
        ROBERT LAFAYETTE
          An excellent Article by Gary Orloff from Jan 2008 AO
          Water pump housing may be 180 degree off?
          KG71
          KG72
          KG7-2
          #200349
            As far as the alignment im not sure. I only removed the cover and didnt mess with the cartridge. Dave has suggested I pull the lower, submerge it and use a drill to spin the shaft and see what kind of pressure it is putting out. The rubber and metal washer were there on the tube. Dave also suggested pulling some things from the top end of the motor to see if there is any impellers in the water jackets. Forgive me for not knowing the proper terms I didn’t even know the motor didn’t have heads until Dave just told me, outboards aren’t my in my wheel house but Im gonna get this one figured out sooner or later..
            #200356
              I remember the cartridge hole being oval shaped instead of perfectly round, anyone know which way the oval goes? Maybe someone before me put it in wrong but if I knew the proper direction i could at least verify that it is in the correct position
              #200363
              ROBERT LAFAYETTE
                Some patent drawing s may help?
                US2466440-drawings-page-1
                US2549477-0
                US2549477-1
                US2549477-3
                #200371
                  Thanks, you guys got all the goods, like a treasure box full of info on this site 🙂
                  #200391
                    • This reply was modified 6 years, 6 months ago by Tubs.
                    #200396
                      #200398
