Home › Forum › Ask A Member › Mercury KE,F&G 7 Damper, gear housing stud
  • #7261
    green-thumbs
      Does the shape of the damper matter?
      Does the location on stud matter?
      Was it free to move or was it fixed to a specific location on stud?
      Need to make a couple.
      A cylinder would be much easier to make than a truncated cone.
      I have a partial part to work from. Part # 21167
      Same part for KE7 thru KG4
      Thanks
      Louis
      #59151
        yes it matters. the small end wedges in when it is installed. goes in the upper half and small end faces down.
        #59156
        jw-in-dixie
          You mean these cones? Where the foot attachment rod approaches the inside rear of the tower housing, there should be two little bumps that stop the cone, keeping the rod from flexing. Very important to include a cone when reassembling a motor. Be sure it is in the correct position, stopped by the little bumps, before attaching the powerhead. Won’t do any good if it falls all the way down to the lower unit.
          My buddy didn’t and the rod broke dropping his lower unit into the river one day. The bottom nut had come off. That nut retainer is very important also. If you can’t find a retainer use a Nyloc nut.
          The rod has a square nut at the top which must be clocked to fit into the recess in the bottom of the block that keeps it from loosening. I think there is a 12-point socket that fits the square nut.
          You can replace that nut with a hex Nyloc nut. Cheers, JW
          #59159
          green-thumbs
            Looks like a little more intense lathe work
            Thank You both for fast response to my dumb question
            Louis
            #59175
              not dumb.
