Getting my KE-4 ready for the water this weekend.
Runs, but has a pretty bad misfire that I believe comes down to a failing condenser on the bottom cylinder. Coil is good, and has great spark when turned by hand. I am thinking that the condenser, when heating up, is shorting out.
Does anyone know the microfarads of the original Phelon condensers? I’d like to either rebuild or replace them with newer alternatives. I’ve had good luck with gutting the old ones and rebuilding them.
I had a .22 uF OMC condenser in there just for testing, but never actually ran the engine with them.
Thanks!
1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
1955 Feather Craft Vagabond - 1956 Mercury Mark 55E
