Make sure you find out what has been rubbing.
Some other issues to mention:
The hole in the center of the metal plate on the bottom of the recoil was enlarged by Mercury in later models. I find motors where the flywheel nut seems to have been rubbing against that plate.
I think there are also different style flywheel nuts used by Mercury and some have taller heights.
Sometimes you find optional flat washers under the flywheel nut as well.
