Home › Forum › Ask A Member › Mercury KD4 impeller
  • #976
    bob-d
      Does anyone know who makes an impeller for a Merc KD4?
      Oldmercs.com use to list them but no longer. I believe the part number is 47-24447.
      Thanks,
      Bob D
      #12485
      JOHN D.
        Those I hear are no longer being made. Checking on the Wizard site a member there mentions using an OMC #382221 and altering the hub to fit. An aomci member by the name Brian Wilcox makes those and needs your core to make a new one. Hope this helps as I haven’t done this myself.
        #12488
          I think it was Ferguson Poole Marine that I got mine from? I placed a wanted ad on the site and got a few quick responses.
          #12491
          bob-d
            Thanks guys. I will look up Brian, and give Ferguson Poole a call.
            Hopefully between the two, I should be able to come up with something.
            Bob D
            #12539
            bob-d
              Thanks Chris P, Ferguson Poole just got back to me, and has the reproduction of the vane type, but said I should check because some of the earlier ones has an oscillator pump instead.
              #12540
              RICHARD A. WHITE
                Yes, that motor came with either, it is simple enough to use either one, just change housings I believe..I think I have a spare vane housing, if you need it I can look.
                classicomctools@gmail.com
                #12557
                bob-d
                  Thanks Richard, I will let you know if I need when I dig into the lower unit.
                  mercuryman
                    I made a impeller for a Wizard WD4 which is about the same motor. Get a OMC 382221 cost about $15, Its the same size as the WD4. It has a plastic hub and you to cut two notches to fit the brass impeller adaptor.
                    #12580
                    bob-d
                      Mercury man, how did you cut the notches? Square file?
                      #12586
                      mercuryman
                        File and Dremel tool
