Home › Forum › Ask A Member › Mercury K Model Clutch Elements Stuck Together
  • #287794
    green-thumbs
      Has anyone found a technique to separate the rubber element from metal disc of the Early Mercury K Model Clutch Assembly? I would like to restore the clutches for reuse. Prying and pulling worked on one assembly, but, not on these 3. Boiling, Freezing, Vinegar soak WD40 are under consideration.
      #287804
        1. Not sure this is true but I don’t think it ever was intended to come apart there. Clutch release was acomplished by the notched part hopping over a bump when an obstruction was hit
