Home › Forum › Ask A Member › Mercury fuel fitting repair?
  • #280574
    davidk
      Is there a way to repair the Mercury fuel fitting to stop it from leaking?  Must be an O-ring or a seal in there that the ball pushes up against when you disconnect.  Is there a replacement?  How do you get at it?
      IMG_0035-1
      #280576
        buy a new one… walmart   amazon etc,,,
        the small ones for low  Mercury ‘s  from the 60-70’S  hp like the 4-6- 7.5 hp     are more $$$$
        #280579
          Not sure about Merc fittings but here’s a Scott McCulloch fitting apart for O ring servicing.  Heat had to be used to loosen the sealer holding the two main parts together.
          This fitting also fits the small Merc motors so it might be similar in construction.
          Fuel-Fitting
          #280581
            Yes, merc is similar.
            #280584
            davidk
              I’ll try heat and see if I can get it apart…while I buy a new one.   : )
              Thanks for the responses.
              #280586
              davidk
                davidk
                  Came apart easy with some heat.  The older thread suggests dash 205 o-rings.  Any suggestion on ethanol/fuel resistant o-rings? Good source?
                  IMG_0038
                  IMG_0040
                  #280600
                  davidk
                    Double post
