Home › Forum › Ask A Member › Mercury force 120 misfiring pics of spark plugs
  • #288150
    Beno
      I believe it.
      But this particular case on a mercury force jet boat : the only thing that changes is the direction of the nozzle at the end of the boat. .. and I guess the center of gravity. .
      Could you imagine if one day transparent aluminum is invented? (Star Trek 4). You’d be able to see right inside your engine and you can see the ignition chamber and see the exhaust..
      Of course it would be covered in muck..
      #288157
          Fill a glass of water 1/2″ from the top and swing it in one direction or the other. The fuel in the carburetors do the ssme thing. If there is a problem with a float setting, as fleettwin suggest, extra fuel may be spilling into the intake flooding the motor for a bit. Tubs .
        #288173
        Beno
          F14
          Sea trials underway
          #288184
            Hopefully the sea trails are for the boat and not the tractor!
            Beno
              I don’t know if you can see it .. but there’s actually a 2-in ball hitch receiver bolted to the side of the bucket that I move that trailer around with..
              Works okay but I think I’m going to move into the center of the bucket in the future
