Home › Forum › Ask A Member › Mercury Dull aluminum paint
  • #8016
    cheetahgod
      Looking for mercury dull aluminum paint.
      Also what primer should I use for coating a inside merc steering bar? I think its steel.
      Thanks
      #63763
      RICHARD A. WHITE
        Anyplace the sells Dull Aluminum in spray can, auto supply stores should be able to help you out
        classicomctools@gmail.com
        #63765
        bkrsdoz
          I used Rustoleum Matte Nickel. It was a perfect match.
          #63786
          cheetahgod
            thanks
            #63795
            cheetahgod
              Does it matter if it’s automobile paint or not?
              #63892
              baron0418
                I have always used Tempo #808 dull aluminum. It is also a perfect match. But it is Lacquer. I know there are other paints that are a equally good match. I use the tempo because it is very easy to touch up if needed.
                #63920
                RICHARD A. WHITE
                  quote Baron0418:
                  Tempo, that is the name I could not think of, ..that is what I have always used…
