Home › Forum › Ask A Member › Mercury distributor
  • #1287
    motoscott909
      hey guys,
      I am working on my Mark 75 and want to replace the top bearing in the distributor (under the pulley) and am not 100% sure how it comes out. It appears that there are 3 bent tabs that may hold the bearing in, but im not sure? Can anyone lead me in the right direction?
      Thanks!
      Scott
      #14507
        You have it! Requires them to be bent. Be careful not to make a tight 90 degree bend as it needs to be bent back to hold it in place!
        P.S. Be sure to buy a good sealed bearing! A friend of mine had to replace the bearing twice as it leaked grease into the lower area & soaked
        both sets of points & he stopped in the middle of the lake after oil got on the points sets!! True story!!
