Home › Forum › Ask A Member › Mercury 9.9 Mod
- This topic has 8 replies, 6 voices, and was last updated 1 year, 1 month ago by
David Stanton.
September 12, 2025 at 12:58 pm #299836
I have a friend that has a 9.9 Mercury ( Don’t know the year). He wanted to know if it can be changed to a 15hp by changing the carburetor ? I know it can be done on a Johnson or Evinrude 9.9hp just not sure if it can be done on Mercury ? Any suggestions or help would be appreciated. Thanks
September 12, 2025 at 1:43 pm #299837You could try to look up the parts list of the 2 motors and compare parts…
classicomctools@gmail.comSeptember 12, 2025 at 7:47 pm #299847Yes it can be done, have done it several times
September 13, 2025 at 9:26 am #299861Hello group, I recently picked up a 9.9 Merc and would like to try this Hp modification. Would it be just a carb swap or is there any modification to the intake or exhaust as well? Thanks
Gary Kosiba
September 13, 2025 at 10:23 am #299865It would be a whole lot better if we knew the model of the motor you are working with. 2-Stroke? 4-Stroke?
9.9 points to a newer Mercury series; the ones they sold through the 60’s 70’s and 80’s was technically a 9.8.
With Mercury it is always best to work with the serial number.
September 14, 2025 at 9:35 am #299889I have the info now. It is a 110 and the serial number is 4840180. Thanks in advance for your help.
Gary
Gary Kosiba
September 14, 2025 at 12:55 pm #299892OK Gary, your serial number shows a 1978 model which was the long running 10.9 cubic inch block which began in 1962 and went into the 80’s.
Mercury did not offer a 15HP version; they went from the 10.9ci 9.8HP to a 21.9 cubic inch 20HP block.
At a paltry 10.9ci….I doubt that much more performance can be squeazed out of your 9.8. It is already a tuned version of the 7.5HP motors.
September 16, 2025 at 1:22 pm #299915Thank you seakaye12 for the info. I appreciate you taking the time. Gary
Gary Kosiba
September 21, 2025 at 11:01 am #300037Note that the 9.9 replaced that 9.8 in 1986.
