Home › Forum › Ask A Member › Mercury 9.8 Question
  • #6082
    mightymite
      Hello, All, does anyone know the proper points setting for a 1972 Merc 110, 9.8 hp with Thunderbolt ignition?
      Thanks, John, Member
      #50806
        If I am not mistaken .020 don’t clean or dress these points and if they are not new it is hard to set them because of the pitting so leave them alone if they are working. check the plastic insulaters the go bad and will cause no spark.
        #50828
        bob-d
          John, here is some info from the factory manual that might help. Don’t forget to check all of the wiring as those motors have poorly made wires that tend to dry out and crack, exposing bare wires. Pull the flywheel and check.
          #50831
          mightymite
            Thanks guys, The wires were bad . I,m in the process of replacing them now.
