Home › Forum › Ask A Member › Mercury 9.8 drive shaft issues
  • #2237
    billy-t
      Hi All
      Well finally got around to changing the impeller on the Mercury 9.8 and all was going fairly well until I noticed that the splines on the top of the drive shaft are badly worn. Doesnt look like this motor has many hours left on in! Are these still available? Likely pricey, better to look for a good donor motor I guess.
      It didnt appear that there was any oring to keep water out of power head like on the Johnson stuff. Interesting.
      Bill
      #21840
        What year/serial #? There should be plenty of drive shafts, considering the number of bad gear sets and blown cases out there.
        #21851
        raglover
          I am not an expert on the Merc 110’s but in the few I have pieced together I did notice differences in shift shafts and such if you were not swapping an entire lower unit out, and on the shift shafts the upper portion had to be considered too. Not sure about the drive shafts but a check on marine engine parts diagrams could probably confirm the part numbers in matching years.
          As for the worn splines, it may be a good idea to shine a light up to the crank shaft to make sure that it is not worn as well, or at least help you make a judgement call on what to spend.
          Good Luck
          #21881
          20mercman
            I have seen worn splines on the 200’s, but not on the 110’s. The drive shaft should be interchangeable for this motor from a lot of motors from 6hp, 7.5 and 9.8hp. On the 200 I had, I had to turn the crank against rotation of the lower unit to get the thing to let go, it was like a twist lock. The splines in the crank were fine, so it must have been a poor heat treating issue. This was on a 1969 motor, and I have also seen wear on the stainless shafts as they are softer then the carbon steel shafts. Don’t condemn a motor for just a drive shaft, as they are around.
            Steve
            #21897
            billy-t
              Thanks, I will look around for a drive shaft. Of course, everything is less plentiful here in Canada as there is less of us and less motors too.
              But perhaps some merc guys could enlighten me a little. If there are two different impeller sizes does that mean there are two different shaft alternatives out there too and are they interchangeable between motors?
              Thanks I do appreciate the advice of those that do know more than me.
              Bill
              #21898
                Dave B where are you? Dave is a great guy for driveshaft & anything Mercury relted. Isn’t there a cd out there on Mercs on what fits what? Have seen it somewhere, maybe JOM"S site I saw it.
                #21904
                Doug Wilson
                  was thinking there was supposed to be an O ring near the top to keep the water from getting there but would have to pull one apart to check.
                  Doug
                  turned off?
                  #21913
                    There’s a little piece of felt or something or a seal inside the end of the crank extension which is supposed to hold oil or grease.
                    One interesting note here. On one 9.8 I saw, the hole and splines in the end of the crank were machined right thru the crankshaft. The motor never did run right as pressure and vacuum were going thru the spline area.
                    #21928
                      Yes, there are two different shaft diameters to match the three (that I know of) different impellers and the difference is only a few thousandths of an inch. There are many more variations of the shafts, depending on serial number. There are two ways to get the right part for a Mercury: Serial number or trial and error. With emphasis on ERROR. Save yourself some serious grief and shop by serial number and part number.
                      #21945
                      billy-t
                        Okay so here is the information
                        Canada Serial number 7074683
                        It would appear to take drive shaft part number 75034 or 45-75034 depending on which site
                        it would appear that the same drive shaft should be found on motors in Canada with serial numbers 7049108 and up
                        Sooooo……. would i be correct in assuming that if i can find a parts motor with a serial number of 7049108 or higher it might have a drive shaft that would work?
                        suggestions
                        Bill
                        Thanks for any
