Home › Forum › Ask A Member › Mercury 50 hp 1967
- This topic has 15 replies, 5 voices, and was last updated 11 years, 4 months ago by
billw.
June 23, 2015 at 11:21 pm #1845
I’m looking at buying a 50 hp Mercury 4 cyl from 1967 serial number 2247022. It’s been sitting for some years now. I’m just wondering how hard it is to change the impeller and any other basic work that might need to be done. Do you need special tools etc. Also can anyone tell me if parts are still available?
June 23, 2015 at 11:28 pm #18785if it is not a salt water motor it is no problem. common tools.
June 24, 2015 at 12:12 am #18789changing impeller is a piece of cake just unbolt the lower gearcase to access the pump
absolute great engine !! check u tube for videos
owned one years ago… great troller smooth engine
do basic checks before going to far
compression ignition, carbs will need to be redone
June 24, 2015 at 12:18 am #18790I would make sure it has spark, before you buy it. CD ignition parts are pricey and the triggers are getting hard to find, even pricey ones. They are NLA for Mercury Marine.
To come at what Dave said from a different angle, if it was ever a salt water motor, don’t walk away….RUN, or your life will become a living hell. This is coming from a salt water Mercury mechanic who generally likes Mercurys. If it’s fresh water and has spark, it will be a great-running motor, one of the nicest sounding idlers ever built.
June 24, 2015 at 2:36 am #18799I have the energizer parts in great shape if anyone needs good price.
June 24, 2015 at 5:30 am #18803BillW, I knew a Merc guy who told me about an old, white Merc counter-rotation motor, the whole motor turned counter-clockwise. He said if I ever came across to run like….
June 24, 2015 at 11:47 am #18809What would be good compression on a motor like this?
June 24, 2015 at 12:54 pm #18811120lbs is like new. even is what you are looking for.
July 3, 2015 at 3:08 am #19378One more question, can you convert a long shaft to a short shaft and if so what years are compatible with 1967. Is it a simple lower unit change?
July 3, 2015 at 9:58 am #19391It is not simple at all, sorry to say. The entire drive shaft housings are different, shift shaft, drive shaft….etc. To change the drive shaft requires a good bit of gear case disassembly, which technically would involve re-shimming the pinion gear, at the very least. I’m going to be totally lazy and not look this up; but there is even a good chance that the 20" swivel bracket is longer than the 15". In a lot of cases, the 20s had shock absorbers and the 15s didn’t. The 15" stuff is pretty rare to find, too, in my experience….
