Home › Forum › Ask A Member › Mercury 210CI Sail Motor
  • #3725
    james-davis
      Anyone know anything about Mercury Sailmaster outboards, picked one up today and can’t find serial number, newer than I’m used to. Anyone know where number would be. It’s a long shaft and was cheap, faded outside clean under hood. Jim
      #32616
      mercuryspecialist
        Hi James,
        I think you are asking about a 1986-89 offered 210cc Sailpower. The serial number was factory placed on the starboard side of the swivel bracket on likely a decal. A matching cylinder block serial number I think is on the starboard side (of the cylinder block – ? on a casting plug). They were basically a 20" or 25" Merc 9.9 horsepower with factory installed battery charging coil and rectifier, and a low pitch propeller suited for use on a sailboat. I seldom login here, so if you should send me a private message, do write a note here so that I will know to check.
        Regards,
        Joe
