Home › Forum › Ask A Member › Mercury 20hp Prop?
  • #323850
    bunky
      I have a Mercury 200 20hp mid 70’s 2 blade prop.    The prop is worn and i would like to replace it.   I have the motor on a 14ft sea nymph 14R      when looking for a replacement most appear to be 3 blade props.      Do I go with a 3 blade or try and find a 2 blade ?
      Any suggestions on a prop ?
      #323909
        if what you have…..ran good for you use the same
        any decent prop  shop will make it like  new again  if you can wait a bit.   They   usually have spares on the wall !     maybe they can just do a swap  …yours for their propr    already refurbished  .  May be cheaper that buying new !
