Home › Forum › Ask A Member › Mercury 200 Water Pump
- This topic has 11 replies, 6 voices, and was last updated 11 years, 3 months ago by
chris-p.
July 23, 2015 at 9:37 pm #2086
Im servicing a Merc 200 20hp water pump. Motor I found in a barn.
Everything was corroded on this bugger. I had to grind the prop apart to get it off, after melting the hub with a torch to get that off first. The bolt under the anode was severely corroded, so had to cut a hole in the anode over the hidden bolt to get that out. Boy are those anodes tough to drill through!
Anyways, the seal on top of the impeller housing is rotten. I picked it all out, and thought I could press a suitable sized oil seal in there? I have something that would work but would need to dremel out the hole a touch to get the seal in. Anyone done this before? The seal that is original in there does not look like it would do a great job? The hole looks eccentric though, and off round? Like I would only need to dremel out half the hole? Does this sound like a plan, or are these seals fairly common.
cheers
July 23, 2015 at 10:00 pm #20725I didn’t have any trouble finding a seal for my ’68 lower unit/water pump…I think I got them from MarineEngine.com. I can’t remember off the top of my head, but they may also use a slinger on the driveshaft just on top water pump housing and seal.
July 23, 2015 at 11:37 pm #20728Yeah I found the remains of a slinger, thanks!
Ill post a wanted ad in the webvertize for some parts thanks!
July 24, 2015 at 4:35 pm #20760Parts? I just got rid of a ’65 200. I would have given you anything you wanted off it! 😯
http://www.usedvictoria.com/classified- … e_25580043
July 24, 2015 at 7:49 pm #20768I have been trying to locate the seal and a prop. I had to cut mine off! Im sure one will turn up , thanks though Mumbles.
July 25, 2015 at 3:19 am #20801Prop should be no problem on eBay.
July 25, 2015 at 3:37 am #20804might have a prop how many splines
July 25, 2015 at 4:05 am #20806quote Mumbles:Parts? I just got rid of a ’65 200. I would have given you anything you wanted off it! 😯
AAAAAAHHHHHHHH!!!!!!!!!!!!! I am missing a 65 200 from my collection!! That would look fantastic next to my 63,64, 66…..etc. 😥
Steve
July 25, 2015 at 12:46 pm #208258 spline with 9P44 on it
July 25, 2015 at 1:44 pm #20827quote jpatti75:I didn’t have any trouble finding a seal for my ’68 lower unit/water pump…I think I got them from MarineEngine.com. I can’t remember off the top of my head, but they may also use a slinger on the driveshaft just on top water pump housing and seal.I believe the seal is part 40 here? They don’t have it listed, nor a part number for it?
http://www.marineengine.com/parts/mercu … ete-page-1
