Home › Forum › Ask A Member › Mercury 1956 Mark 25E starter removal procedure
  • #262706
    HARRY D. NICHOLSON
      What is the procedure for removing this Mercury starter.  It appears that the starter has to be removed from its’ bracket somehow, for screw access, before the bracket can be removed.
      #262714
      opposedtwin
        Harry, you sure that’s a ‘56? Can you post the serial number? I thought the ‘56 model was changed to feature the bendix style starter and changed the recoil cover to accommodate the top part of the starter. That is the earlier “swing” style starter which I thought was only used on 1955 models.
        scott
        #262740
        HARRY D. NICHOLSON
          The sn is 879638. Mark25E.  Year ?
          #262745
          opposedtwin
            Yep, 1955 model. I don’t know about disassembly but i’ll look at mine tomorrow.
            #262746
            HARRY D. NICHOLSON
              Like Rosanna Danna would say :  That changes everything.   Never Mind.
              No need to look at yours unless this 1955 starter is interchangeable with a 1956 starter.
              Thanks for the correction.
