Home › Forum › Ask A Member › Mercury 10A
  • #271127
    scubapop
      Anyone ever replace the water pump 0n a Mercury 10A.  I could sure use some advice for this job.  Recently acquired this little guy and want to be sure that it has a adequate cooling.  Any help or advice will be greatly appreciated.
      #271130
        pain in the !!! and time consuming but can be done if you follow the directions. get the manual!
        #271136
          When you do it, you get a master’s degree in water pump replacement. And patience. It is best if you have some special tools. Some guys have made their own, although I am not recommending that. Any short cut you try to take will end up biting you in the rear end; believe me. Like Dave said, get the manual, too. I own around thirty Mercury engines with this type of pump/transmission set up. The SHORTEST time I ever spent on one was nine hours, to truly do it right. But don’t let all this negativity bring you down. When they are right, they run well and are a pleasure to use. The unique transmission is something everybody in this hobby should experience. Don’t be afraid to ask more specific questions, if and when you proceed.
          #271145
          DAN UMBARGER
            May I ask what a Mercury 10A is? I don’t think I’ve ever heard of that model.
            #271154
              1959-mark 10 A is a mercury auto tranny. shift and throttle in the tiller handle.
              • This reply was modified 3 years, 9 months ago by DAVID.
              #271168
                I did 3 of them.  The first and the last and the one I had to do over when it quit pumping after just sitting on the rack.  Had no instructions and made my own tools.  Some Merc dealers wouldn’t even touch them.
                I have to admit, they were  an engineering marvel.
                Screenshot_20230114_122743
                • This reply was modified 3 years, 9 months ago by frankr.
                #271178
                  Ran a Mark 28A on a 12ft Aristocraft and loved it. ran a long time and traveled many miles in the Chesapeake Bay on a few weekends. Was not afraid of break downs.
                  #271179
                  Matthew Pieklik
                    When I started to work on my mark 28 that was on my rack for about 15 years, I did the water pump and found the locating pin for the impeller cup was missing. The special tools I picked up at auction and at the time, I had no idea what they were for.  Read the service manual and take your time pay attention to the springs and  pawls . I had success and so will you.
                    #271184
                    ROBERT LAFAYETTE
                      A couple good videos on YouTube
                      https://youtu.be/lB4fkM0wvPk
                      #271185
                        I’d always heard changing the impeller on one of these was a real PITA.   Now I’m fully convinced.    Somebody must have stayed up a lot of late nights to come up with this design!   But then again, I’ve heard they were great runners.
                        1982 Evinrude 25hp
