Home › Forum › Ask A Member › Mercdry KG4 carb settings
  • #4925
    bsplit
      What are the initial carb settings for a KG4?
      Thanks,
      Jim
      #41642
      wedgie
        The 1965 and prior service manual mentions low speed one turn out and high speed 1 1/2 out
        What I found confusing at first is the fact that the needle controls air,and not fuel. Turn clockwise to rich up the mix
        #41644
        bsplit
          Thanks, Wedgie…..That’s good to know
          Jim
          #41646
            If the idle needle is in the front rich is counter clock wise for rich. If it is on the side it is clock wise for rich. you can take that to the bank.
