Home › Forum › Ask A Member › merc water pump
  • #272605
    hydrojet
      Looking for the water pump impeller chart I remember seeing thanks Also will a KE7  flywheel ratchet starter nut work on KG7,Kf7, thanks
      #272608
      green-thumbs
        TRICKY QUESTION..,20631 used EXCEPT when using  flywheel  206-750 and magneto 320-746 Bendix K2A-5 So you can use KE7 Starter, Ratchet Nut on KF7, KG7 or KG4, except for above flywheel magneto combination. Per the parts manual.
        KE7 uses impeller 24472 KF7,KG7,,KG4 use 47-21164
        Not sure which impeller chart you want, There have been several articles in Antique Outboarder regarding adapting impellers with some cort of chart included,
        Good Luck
        • This reply was modified 3 years, 9 months ago by green-thumbs.
