Home › Forum › Ask A Member › Merc-o-tronic 9800
  • #4860
    gofastgramps
      I have a merc-o-tronic model 9800 that runs on the internal battery or 12 Volt external battery. I need any information that I can get on it. does the functions that normally use 120 volt work on battery power? If so which battery. any info would be appreciated. Gary
      #41078
      mercuryman
        Not sure what you need, I use a 7.5 volt rechargeable model car battery. It cost about $15 with charger. The 120 volt AC is used in testing capacitors and 7.5 volt DC for coil test.
        #41086
        mercuryman
          You can find a manual on internet you can copy.
          #41164
          gofastgramps
            this tester does not have a 120 volt plug. Gary
            #41168
            mercuryman
              I gave you wrong info I have the Model 98 which must be different than 9800. It must make AC voltage from the battery as it has a circuit board.
