Home › Forum › Ask A Member › Merc MK magneto reassembly help
  • #282694
    Doug G
      This was probably the only disassembly operation that I didn’t take a picture of (I hope).
      when reassembling the magneto would the following order be correct?
      sector gear, brass shim, magneto hold down spring
      #282732
        Dave B. We need your help!
        #282923
        SHELL KOTTKAMP
          I’ll be curious to find out too, facing this on a Mark 25 winter project, she’s in a lot of pieces.
          #282936
          CHUCK WEBSTER
            Check out the diagram of Mark 25 on Marine engine.com. I think the brass shim in last
            #282937
            CHUCK WEBSTER
              Check out the diagram of Mark 25 magneto on Marine Engine.com. Think the brass shim is last.
              #282947
              CHUCK WEBSTER
                Go to Marine Engine and look at Mark 25 magneto. I think the brass shim goes on top of the other two.
                #282948
                Doug G
                  Thank you
