Home › Forum › Ask A Member › Merc KG4 & KF7 block fillers
  • #8343
    mikesea
      Hi Folk’s,
      Back again and this time does anyone know if the same size block filler will fit both the KG4 and KF7 blocks? I have never made an aluminum cast before but am retired and have more time than money. Just a lead on sand to use etc would be a big help if no one has any filler blocks just holding a door open some where Ha.
      Always thanks,
      Mike 😉
      #65495
      chinewalker
        Different blocks. The KG4s used a die cast block, while the KF7 may/or may not have used a sand cast block. Depends on the filler block, too, as some were made for the Quincy exhaust, while others were made to go with the toilet bowl Mark 20H exhaust.
        #65516
        mikesea
          KG4 block does look like a very clean casting. I have not opened up the KF7 yet.
          #65537
            I may have an extra filler block if needed. 1 914 310 7086. Dave.
