Home › Forum › Ask A Member › Merc KE-4 choke plate
  • #7385
    ronboonville
      Can anyone post a pic of how the choke plate works? I’m not doing something right.
      #60068
      mercuryman
        KH7 but should be same as KE4
        ronboonville
          Thanks! I see that I am missing that wire clip. Do you know where I might get one?
          #60075
          mercuryman
            http://www.marineengine.com/parts/mercu … r-assembly
            Try here under KE4 they don’t show one.
            #60081
            ronboonville
              download/file.php?mode=view&id=9882 my plate set up is different. rod pushes to choke, and pulls to unchoke. I am doing something wrong.
              mercuryman
                You have a AJ32A that is used on KG7 & KH7 that is the wrong plate for that carb. If you are using the AJ32A on KE4 it won’t run right.
                You need a screw with shoulder to keep the spring from binding, a spring and right choke plate. You pull the choke rod to close choke.
                Go to Marineengine.com and look the the setup for you engine.
                #60086
                ronboonville
                  I think it runs great with thttp://aomci.org/forum/download/file.p … id=9885his carb, I think that carb was used on the ke-4 hd
                  mercuryman
                    Could you have a KG4
                    #60089
                    ronboonville
                      I thought it was a KG-4 for some time, but the badge does say KE-4. Help educate me, I am old and confused quite a lot. If you can explain the difference I would appreciate it.
                      #60090
                        here is the setup for a KE4.note the carb is a AJ23A not an AJ32
