Home › Forum › Ask A Member › Merc K series engines Mag to Electronic Ignition
  • #8243
    mikesea
      Hi Folk’s,
      Anyone made the switch to a Electronic ignition system?
      Thanks,
      Mike
      #65011
      mercuryman
        If you are talking about the Bendix Magneto and the Nova ll type modules they won’t work. If you pull the plug they will make a good spark. But with the plugs in compression keeps you turning the motor fast enough to make spark.
        #65038
        jw-in-dixie
          So, do they work okay with Phelon?
          #65043
          mercuryman
            They work on OMC coils so should work on Phelon. The magnet is on outer edge of flywheel and moves faster on OMC and Phelon. Might work on Bendix if you could fast . I am 80 and can’t do it.
            #65060
            jw-in-dixie
              The old saying; "Anything will work if you crank it fast enough." I’m 85 and fully understand. 🙁
              #65102
              mikesea
                Thanks Guy’s
