Home › Forum › Ask A Member › Merc . 800 1969 no fire when turning over
  • #2770
    cannuck
      This one is weird . Bump starter fires on each 4 cyls. turn key off and on fire at wire individually. will not fire when spinning over ?? 80 hp w/ switch box and w/trigger pick up Thunderbolt ignition any clues all grounds and voltage are right
      #25559
        key switch might be bad.
        #25570
        cannuck
          Thanks Dave but there is power on switch box when spinning and trigger side . So does that rule out switch ??
          #25574
            check the voltage starter may be draining the volts away.
