Home › Forum › Ask A Member › Merc 115hp Water Pump
  • #4164
      Dropping the gearcase on a early 90s 115hp Merc tomorrow.
      I always forget, do you shift into forward, or reverse before dropping it? Or am I thinking of another model here? I believe this model has the shaft style shift rod. Nothing to disconnect, you simply have it in a certain gear to lower or install the gearcase correct?
      Thanks.
      #35716
      20mercman
        They will drop in any gear, but I find it is easier to have it in forward when you take it apart, as you know where you are when going back together. You can also spin the prop to move the drive shaft splines to aid alignment. It is just a matter of getting the water tube, shift shaft and drive shaft all aligned at the same time. Really not that big of a deal.
        Steve
        #35724
          Forward is the factory-recommended way. However, my two cents is that I like neutral better. There is a lot of possible radial movement in forward, on the gear case side of things; whereas in neutral, things tend to stay more lined up, in my opinion. I have done many, many of them that way but do what you want. Whatever you do, DO check that it works, before you go launching the boat at the public ramp.
          #35739
            Great, thanks both!
            Ill get the old tower of gas consumption on the water this week.
