Home › Forum › Ask A Member › maximum outboard sizes on smaller cedar strip boats?
- This topic has 15 replies, 9 voices, and was last updated 10 years, 6 months ago by
shoestringmariner.
April 20, 2016 at 1:59 pm #35131
Tubs,
Your photo is wonderful! So much color too. i’m from the desert & it can be colorful but there is something about the river in the forest that is beautiful.April 20, 2016 at 11:27 pm #35159Thanks for setting me straight on the PM system. I just thought the messages were stuck.
I also agree with Jeff, the lighting in that photo is perfect.
April 21, 2016 at 3:35 am #35173This is how it was suggested the boat manufacturers do it . . . . 😀
April 21, 2016 at 3:02 pm #35185A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 12 months ago by
Tubs.
Tubs.
April 21, 2016 at 3:15 pm #35186
Found this information on other site. The author’s handle is Meanmouth.quote :Hopefully this guide will help you calculate the maximum amount of H.P. your boat can be insured for.
– This is to only be used as a guide.
– You can round your final HP number to the closest multiple of 5. (31 HP would round to 30 HP. 33 HP would round to 35 HP)Step One – Compute your Factor
A. Length of Boat x Transom Width (measure in feet: 14, 15.5,16, etc).
Step Two – Compare your factor to H.P. rating
A. 0-35 = 3 hp
B. 36-39 = 5 hp
C. 40-42 = 7.5 hp
D. 43-45 = 10 hp
E. 46-52 = 15 hpStep Three – If your factor is over 52 (Choose only A or B)
A. With Remote Steering (steering wheel) and at least 20″ transom height
Maximum HP = (Your factor x 2) – 90
Example: 19′ 6″ long , 7 feet wide = (19.5 x 7 x 2) – 90 = 183 (Round up in multiples of 5. This boat’s max is 185 hp).
B. With Tiller Steering (hand or extension) or less than 20″ transom height (Choose only 1 or 2)
1. Flat bottom, or hard chined boats (hull has hard angles)
Max HP = (Your factor x 0.5) – 15
2. Soft chine, rounded hulls
Max HP = (Your factor x 0.8) – 25
Conclusion
I hope this has helped you all who are looking for max hp ratings. If your boat is insured, make sure to check with your insurance company for any restrictions.
This guide was found at NewBoatBuilders, which was ultimately used from “Title 33-Code of Federal Regulations-Subpart 183.53”.
April 22, 2016 at 10:14 pm #35268Wonderful, thanks guys. According to the last calculation, 7.5 is my max.
