Home › Forum › Ask A Member › Martin 75 twist shift serial #
  • #1129
    fishmech65
      Hi, Does anybody know where the serial number is located on a martin 75 twist shift?
      #13505
      jasonh
        Mine is on tiller bracket.
        #13510
        bobprock4200
          Fishmech, it should be right on the tiller bracket as JasonH says. If you don’t see one, look closely for two rivet holes where the tag once was. Russ Larson has replacement serial number tags but of course that doesn’t help with finding out what the actual SN was. Good Luck.
