Home › Forum › Ask A Member › Martin 45 -40 power heads
  • #5025
    TOM GOEPFRICH
      Can a Martin 40 power head be used to replace a bad power head on a Martin 45?
      #42400
      JOHN D.
        I just looked at my Martin 45 and it looks like it will bolt right up. Not like trying to convert a 60 to a 75 twist shift. On that, part of the shift linkage bolts to the block. The carb on the 45 is different and maybe the magneto.
        #42405
        TOM GOEPFRICH
          I’d really like to hear from some one that knows for sure they are inter changeable. My 45 appears to have bad center main bearing and there is a "good" 40 power head available on e-bay that I’d like to buy if it’s just a swap.
          #42413
          ladler
            Go to Martin outboards.com. contact Russ and he will help you out
            #42426
            JOHN D.
              I was busy this morning. I do have a 40 block that I was going to compare with one that is assembled. Only takes a few screws to remove. I’m not going to do that now.
