Home › Forum › Ask A Member › merc 60 gearcase oil or grease
  • #280314
    mike n
      helping friend with a merc 60. he put oil in the lower unit and it is leaking out.  is it better to use the grease?
      mn
      #280316
        no grease   find/fix  the leak !!
        where is the leak…..  around the prop shaft, shift, or drive shafts or  fill plugs ….
        pressure test when all done.
        https://www.bing.com/ck/a?!&&p=7e5550bca8cfce17JmltdHM9MTY5NDA0NDgwMCZpZ3VpZD0xNWNlY2Y1MS1lMTllLTZlOGUtMjEyOS1kYzYyZTBhNTZmOTImaW5zaWQ9NTE4MA&ptn=3&hsh=3&fclid=15cecf51-e19e-6e8e-2129-dc62e0a56f92&u=a1L3ZpZGVvcy9zZWFyY2g_cT1kYW5iYXIrcHJlc3N1cmUrdGVzdCsmcmVmaWc9NmZjNzMxZjgwNTdiNGQ0OThlN2EwNzZmNzY2Mjg1MDcmcGM9VTUzMSZydT0lMmZzZWFyY2glM2ZxJTNkZGFuYmFyJTJicHJlc3N1cmUlMmJ0ZXN0JTJiJTI2Zm9ybSUzZEFOU1BIMSUyNnJlZmlnJTNkNmZjNzMxZjgwNTdiNGQ0OThlN2EwNzZmNzY2Mjg1MDclMjZwYyUzZFU1MzEmdmlldz1kZXRhaWwmbW1zY249dndyYyZtaWQ9MTQ0QUQ5MDM2MEYxOTUzMTVEODQxNDRBRDkwMzYwRjE5NTMxNUQ4NCZGT1JNPVdSVk9SQw&ntb=1
        #280317
        David Stanton
          Because the Merc 60 has a gearshift, it should have gear oil.
          Take the prop off and make sure there isn’t fish line behind it that has gotten into the prop shaft seal. Sometimes you get lucky and can just remove the line and the leak will quit.
          Prop shaft seals are available.
          mike n
            ok thank you for the help.we’ll find and fix the leak.what is the best reasonably priced oil
            mn
            #280324
              I agree.  Everything needs to be maintaned. If it was mine I would replace all the gearccase seals. Can’t hold oil when it leaks. With grease the small parts starve for lubercation.
              #280334
                if… and I say if… you  can’t or do not want to fix the leak …..John Deere  corn head grease has been used in gearcases .
                It apparently turns more or less liquid under load   and  resolidifies after  cooling down.
                Water then  separates  out  and  is not emulsified allowing  it to be drained out.
                up to you !
                (224) John Deere Corn Head Grease – YouTube
                #280340
                  The driveshafts in these motors like to rust right below the water pump where the seal is and we all know what that leads to, yup, a leaking seal and a drive shaft replacement.
                  #280341
                  elgin2
                    My Dad had one with a rusted driveshaft. He had it built up by welding it and turned down to correct diameter. Didn’t have the motor long afterwards to find out if it worked or not.
                    #280364
                      While Corn Head Grease (top picture) may
                      liquefy in the video, that’s not the case when
                      its in a gear case that is being water cooled.
                      These pictures are straight out of the lake.
                      The benefit of using Corn Head Grease,
                      Cotton Picker Spindle Grease, or Lubriplate
                      105 (bottom picture), is that even though water
                      has entered the gear case it doesn’t mix with
                      or reduce the grease. Even though there was
                      only 5% or less grease remaining in the gear case
                      (bottom picture) what did remain was clinging
                      to the gears. I believe that would be the same
                      for the shafts and bushings.
                      If I could put seals in my early motors and
                      keep out the water, I would use gear oil in them.
                      I only have 5 direct drive motors with seals, but
                      if for any reason I couldn’t keep the water out, I
                      would use one of the greases above as I feel
                      they would provide better lubrication than
                      watered down gear oil.
                      Just another guy on the internet –
                      use your best judgment.
                      #280694
                      JOSEPH BRINCAT
                        The JD Cornhead grease and I presume also the 105 have a special property called Thixotropic, defined as….
                        “the property of becoming less viscous when subjected to an applied stress, shown for example by some gels which become temporarily fluid when shaken or stirred”
                        So, if I understand this, when the grease is “working” it becomes less viscus, then at rest it thickens up. This all sounds great for our old gear cases lacking modern seals.
                        And as Tubs suggested, I’m sure that temperature has an influence also.
