Home › Forum › Ask A Member › Mark 30 magneto removal
- This topic has 4 replies, 3 voices, and was last updated 1 year, 1 month ago by
jeff-register.
September 23, 2025 at 3:54 pm #300090
Does anyone know the easiest way to remove the mag on a Mark 30?
September 23, 2025 at 4:17 pm #300091Remove the powerhead…. then it drops right out, other than that, it does actually drop down far enough with the powerhead installed, but it is not always a fun project….If you pull it, might as well replace the bearings while you are in there… call it preventive maintenance..
classicomctools@gmail.com1 user thanked author for this post.
September 23, 2025 at 8:20 pm #300094I have never pulled a powrhead on one. Is it a simple as removing the bolts and disconnecting the shift?
September 24, 2025 at 7:23 am #300110Dropping the mag is somewhat easy, contorting it to get it out of the confined area and then putting it back is what is fun, but it can be done.
Having done it before, that is the route I would pursue. Drop the mag, pulling the powerhead was meant as a slight joke…sorry..lol
classicomctools@gmail.comSeptember 24, 2025 at 1:50 pm #300125Do not try to replace the drive extention bearings, you will never get it back together! Believe me I tried. They were sold as a unit from Mercury. If they are tight or sticky soak in gas, turn (after a few days) & repeat until free then replace the grease fittings & grease until it turns easy & smooth.Several friends at johns old merc told me thats what they all do. Everyone misses the grease fittings on the drive extention & the bearings dry out. Be patient & soak for a fewdays! Also the distributer and rotor are upside down as you see. A Mercury rotor pulling tool is required to remove the rotor from the shaft or you WILL BREAK it I promise you. What color is the distributer cap? Some years are much better. Please replace the condenser while your there. I would bet its bad from age. Very few know to adjust the points spring tension, but its in the book, too stiff it will wear out the rubbing block, too weak & the points float!. The testing toolMAYbe hard to find but Mercury made one. Check the coil with a meter ohms scale secondary winding & look for cracks or little blow out pin holes on the outside. If you need more help send me a message here, I check every few days. Jeff
P.S. Replace the drive belt too! Be patient building the mag & be rewarded with a reliabe motor!
